Data Explorer - Advance mode - DQL
yuval1983
Guide
Hello everyone
Is it possible to do the following? I would like to see, in the same line, the errors of 5XX and 4xx but in the same line. It is in relation with these metrics:
Is it possible to add in advanced mode? Maybe and so that they display data in the same line.
Is it possible to do it using DQL?
Thanks.
6 REPLIES 6
rastislav_danis
DynaMight Pro
DynaMight Pro
What's your expectation ? You need to add both rates into single value as average ? Then you can simple do ((builtin:service.errors.fivexx.rate:...)+(builtin:service.errors.fourxx.rate:...))/2, where ... are your filters.
Alanata a.s.
AntonPineiro
I do not understand your requirement totally, but if you change visualition to table, you will have service name, 4xx and 5xx in one row:
Best regards
I want to add an additional dimension to the "split by" in the metric builder, that in addition to the KeyRequest there will bee a display of count of 2xx/4xx/5xx per request. so it will look like this (taken from the services page)
If I understand you correctly. Those cannot be added in a single row without Grail and DQL.
Best regards
How can I generate these details within DQL.
I have just edited your original message adding DQL, and move it to DQL section.
I hope someone can provide an answer about it.
Best regards
