02 Aug 2018
		10:29 AM
		19 Oct 2022
		01:22 PM
By going to slack integration on Dynatrace there's a title field. In slack webhook creation page, there are clear instructions that body message should be sent in two ways:
You have two options for sending data to the Webhook URL above:
payload parameter in a POST requestI've tried both, and both outputs json as plain text in slack channel. Why? I want to have beautiful post like sentry has for example.
In the end what we have is plain text notifications which is not good at all, as you don't use main slack feature.
02 Aug 2018 12:36 PM
What's wrong with using the out-of-the-box Slack integration Dynatrace provides? See here:
Here you find a blog post about the set up configuration:
https://www.dynatrace.com/news/blog/dynatrace-now-...
08 Aug 2018 09:07 AM
Interesting. I don't get anything similar to that. Here's what I get in specified channel, there's no description only plain text I've entered to that title field
