LocationSão Paulo (AWS)Start timeJun, 12 2024 - 10:14:39End timeJun, 12 2024 - 10:16:04Execution typere-runError code1701 - The specified target window was not foundFailure reasonThe specified target window “window[0].frames[6]” is not foundFailure urlhttps://www.bci.cl/personas
Show only events with timings
This usually occurs when the action from the previous event has not had enough time to complete. Take a look at the screenshots for the monitor. Did the page load as expected? Can you see what you would like to click on? If you can’t I would try changing the wait in the event before the one that is failing. ‘Wait for next event’ is usually a good choice for this.
