Add Node.js Event Loop Metrics to Dashboards V2 Using DQL
Hi, I’m trying to get timeseries tiles about common Node.js event loop metrics to be viewed in Dashboards V2, but the tile seems to show false values ( around 5% avg.) When the host event loop dashboard shows values around 5% to 66% utilization.
Hi @mouru ,
Your image seems to only show the result of your tile. It also looks as though you were using some kind of a query to create this dashboard - if so, what was the query that you used to create the timeseries? If not, how did you create this tile?
This timeseries is straight from Data Explorer, which shows the Event Loop Utiliziation correctly, I just pressed the Open with Dashboards.
The query:
timeseries utilization=avg(dt.runtime.nodejs.eventloop.utilization), by: { dt.entity.process_group_instance } , filter: { in(dt.entity.process_group_instance, classicEntitySelector(“type(process_group_instance),entityName.equals(process_name)”)) }
Hi, now that most of the NodeJS metrics are available in Grail, when will the tick frequency and tick duration made available in Grail?
builtin:tech.nodejs.uvLoop.totalTime
builtin:tech.nodejs.uvLoop.count
It seems to be not available at all here:
Hey @mouru ,
I just wanted to check in and see if you still need help with this. If so, I’d be happy to look into it for you! :blush:
Hi, how that the nodejs metrics are available in Grail I am more than pleased, this is resolved.
