# Add these values
**URL:** <https://community.dynatrace.com/t/add-these-values/43518>\
**Category:** DQL\
**Tags:** dql\
**Created:** [January 9, 2024, 2:14pm UTC](https://community.dynatrace.com/t/add-these-values/43518 "2024-01-09T14:14:22Z")\
**Posts on this page:** 20\
**Page:** 1
<div class="post-metadata">
**Author:** ![yuval1983](https://avatars.discourse-cdn.com/v4/letter/y/0ea827/32.png) [@yuval1983](https://community.dynatrace.com/u/yuval1983)\
**Post date:** [January 9, 2024, 2:14pm UTC](https://community.dynatrace.com/t/add-these-values/43518/1 "2024-01-09T14:14:22Z")
</div>
Hi
I want to add these values filter and I want it to affect what is in the view
fetch dt.entity.service
| fields entity.name, managementZones = managementZones
| filter matchesValue(managementZones, “prod”)
| expand tags
| filter contains(tags, “prod”)
The code that is displayed is
const processedResults: MetricResult[] = metricQuery.result[0].data.map(result =\> { return { “Service Name”: result.dimensionMap[“dt.entity.service.name”], “Service ID”: result.dimensionMap[“dt.entity.service”], “Tag”: result.dimensionMap[“dt.entity.service”], “Failure Rate”: +result.values }; });
Is there something I can write instead of dt.entity.service ??
**Author:** ![gbaudart](https://avatars.discourse-cdn.com/v4/letter/g/e47c2d/32.png) [@gbaudart](https://community.dynatrace.com/u/gbaudart)\
**Post date:** [January 9, 2024, 2:46pm UTC](https://community.dynatrace.com/t/add-these-values/43518/2 "2024-01-09T14:46:22Z")
</div>
hi&nbsp;[@yuval1983](https://community.dynatrace.com/user/60894)&nbsp;,
When I run these 2 queries independently, I don’t get any errors on my side.
Are these two different requests? Can you provide us with a screenshot of your query with the visible error please?
**Post date:** [January 9, 2024, 6:24pm UTC](https://community.dynatrace.com/t/add-these-values/43518/3 "2024-01-09T18:24:27Z")
</div>
I want to filter the table by total of TAGS and ZONE, including a cut according to the filter below, instead of filtering only before the service name.
 ![yuval1983_0-1704824461503.png](https://global.discourse-cdn.com/dynatrace/original/3X/6/7/67f56fe3bf80436d54936f55a9c83cba2c15a4ff.png)
**Post date:** [January 9, 2024, 7:34pm UTC](https://community.dynatrace.com/t/add-these-values/43518/4 "2024-01-09T19:34:43Z")
</div>
To use these 2 filters in the same query, you may test :
```markup
| fields entity.name, managementZones, tags
| filter matchesValue(managementZones, "prod")
| expand tags
| filter contains(tags, "prod")
**Post date:** [January 9, 2024, 9:09pm UTC](https://community.dynatrace.com/t/add-these-values/43518/5 "2024-01-09T21:09:11Z")
</div>
```markup
| expand tags
 ![yuval1983_0-1704834659168.png](https://global.discourse-cdn.com/dynatrace/original/2X/2/296a2dfc059acb0d91c5100f5360adb2a83c6c89.png)
![yuval1983_1-1704834747815.png](https://global.discourse-cdn.com/dynatrace/original/3X/c/6/c633d3d788c5b2d38dad59a2f4c3899ea8e486c0.png)
Ok, I want to filter the results based on services and tags and display them in a window (table). The filter will look like this: services:test, tags:test2. Also, the Zone:prod .
What should I replace in this setting?
“Zone”: result.dimensionMap[“dt.entity.service”],
import { metricsClient } from ‘@dynatrace-sdk/client-classic-environment-v2’;
export default async function fetchMetricResults() {
const serviceSelection = $Service;
const metricKey = “builtin:service.errors.total.rate”;
const config = {
metricSelector: buildQuery(serviceSelection, metricKey),
resolution: “Inf”,
to: $dt\_timeframe\_to,
acceptType: “application/json; charset=utf-8”
if (config.metricSelector.length \> 3500) {
return “Please select fewer services”;
const metricQuery = await metricsClient.query(config);
return {
return processedResults;
function buildQuery(inputs: string[], metricKey: string): string {
const filters = inputs.map(
input =\> `in(“dt.entity.service”, entitySelector(“type(service), entityName.equals(~”${input}~“)”))`
const filterString = filters.join(“,”);
return `${metricKey}:filter(or(${filterString})):splitBy(“dt.entity.service”):sort(value(auto, descending)):names`;
**Post date:** [January 11, 2024, 7:22am UTC](https://community.dynatrace.com/t/add-these-values/43518/6 "2024-01-11T07:22:23Z")
</div>
HI,
I’m not looking for an error
 ![yuval1983_0-1704957294747.png](https://global.discourse-cdn.com/dynatrace/original/3X/e/e/eeafa254c2bb929b66b52ccaf6f0552bb59fde51.png)
I have created a dashboard and added filters for Service, Zone, and Tag. The filter for Service is working fine and the dashboard is being filtered accordingly when I select a service. However, when I try to filter by Zone or Tag, it doesn’t work and doesn’t display the required information on the dashboard.
I have checked the code and noticed that the following code is used for Service filtering:
But, I am not sure what code I should use for Zone and Tag filtering. I am not sure which “dt.xxx” I should use for Zone and Tag filtering or what I should configure in the code for filtering by Zone and Tag.
**Post date:** [January 11, 2024, 8:00am UTC](https://community.dynatrace.com/t/add-these-values/43518/7 "2024-01-11T08:00:01Z")
</div>
mz and tags are not Dynatrace entities. you will therefore not have an equivalent in dt.xxx. you have to find a workaround
**Post date:** [January 11, 2024, 8:24am UTC](https://community.dynatrace.com/t/add-these-values/43518/8 "2024-01-11T08:24:46Z")
</div>
oK
The classic bashboard I can do this filter there according to TAG
Why can’t it be done here?
![yuval1983_0-1704961280352.png](https://global.discourse-cdn.com/dynatrace/original/2X/0/001044783d86b43b1cc2c7f553a9c13b0ea57094.png)
**Post date:** [January 11, 2024, 8:33am UTC](https://community.dynatrace.com/t/add-these-values/43518/9 "2024-01-11T08:33:34Z")
</div>
I’m not saying we can’t filter on tags, just that there is no dt.xxx for tags.
When I want to filter on tags with Grail or the SDK, I generally use an EntitySelector.
However, I am not strong enough in SDK code to easily reformulate your “query”
**Post date:** [January 11, 2024, 10:03am UTC](https://community.dynatrace.com/t/add-these-values/43518/10 "2024-01-11T10:03:02Z")
</div>
HI
I was able to create the filter that I needed. Now, I just need to link it to the code inside the table, which I attached above. I’m not sure how to insert this filter into the table’s view.
| expand tags
| filter contains(tags, “Planning and stability”)
| fields managementZones, tags
 ![yuval1983_0-1704967248386.png](https://global.discourse-cdn.com/dynatrace/original/2X/a/a0963c1543535161ffaab565f772e83096bfaa64.png)
**Post date:** [January 11, 2024, 10:15am UTC](https://community.dynatrace.com/t/add-these-values/43518/11 "2024-01-11T10:15:00Z")
</div>
If you “simply” have to take the filter value.
I think, You may use the $FILTER variable :
```markup
$Tags_PlanningAndStability
**Post date:** [January 11, 2024, 10:57am UTC](https://community.dynatrace.com/t/add-these-values/43518/12 "2024-01-11T10:57:12Z")
</div>
OK
Could you assist me in inserting a value into this code? I am having trouble inserting it in a way that it will filter rather than tag. Below is the code that I have mentioned earlier
const config = {
resolution: “Inf”,
return {
“Tag”:&nbsp; xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx,&nbsp;&nbsp;
**Post date:** [January 11, 2024, 11:02am UTC](https://community.dynatrace.com/t/add-these-values/43518/13 "2024-01-11T11:02:22Z")
</div>
Try this :
```markup
const processedResults: MetricResult[] = metricQuery.result[0].data.map(result => {
return {
"Service Name": result.dimensionMap["dt.entity.service.name"],
"Service ID": result.dimensionMap["dt.entity.service"],
"Tag": $Tags_PlanningAndStability,
"Failure Rate": +result.values
On the other hand, to improve the rereading of your code, you should indent it
**Post date:** [January 11, 2024, 11:17am UTC](https://community.dynatrace.com/t/add-these-values/43518/14 "2024-01-11T11:17:30Z")
</div>
There is progress now, and I can see the value. However, the filter doesn’t really perform a filter like the service filter’s function. It only shows what I mark inside the filter.
The classic dashboard where I make the change in the filter by filtering, so I see what service is inside that tag.
Thank you for your assistance and patience.
 ![yuval1983_0-1704971590598.png](https://global.discourse-cdn.com/dynatrace/original/2X/b/bbdc8cb3aa673ca849eafb712d0cd389ebe6c7ed.png)
**Post date:** [January 12, 2024, 5:40am UTC](https://community.dynatrace.com/t/add-these-values/43518/15 "2024-01-12T05:40:59Z")
</div>
hi [@Pawel\_Zalewski](https://community.dynatrace.com/user/66060)
Maybe you have a solution ?🙂
**Author:** ![Pawel\_Zalewski](https://dub1.discourse-cdn.com/dynatrace/user_avatar/community.dynatrace.com/pawel_zalewski/32/8101_2.png) [@Pawel\_Zalewski](https://community.dynatrace.com/u/Pawel_Zalewski)\
**Post date:** [January 12, 2024, 9:12am UTC](https://community.dynatrace.com/t/add-these-values/43518/16 "2024-01-12T09:12:50Z")
</div>
Hi yuval1983,
I’m afraid I don’t have idea for solution 😞 But I see you made a big progress with&nbsp;[@gbaudart](https://community.dynatrace.com/user/64996), nice work&nbsp;👏
**Post date:** [January 12, 2024, 10:14am UTC](https://community.dynatrace.com/t/add-these-values/43518/17 "2024-01-12T10:14:49Z")
</div>
I was able to link a tag to the table, but you pointed out that the name of the service in the table is incorrect. I would like to display all the names under the same tag group. I need help figuring out how to do it.
![yuval1983_1-1705054426836.png](https://global.discourse-cdn.com/dynatrace/original/2X/e/eb48b624d45537c5e99f37e79932d6e1473d4af7.png)
 ![yuval1983_0-1705054415081.png](https://global.discourse-cdn.com/dynatrace/original/2X/7/7a3b0f39e8baa114061adc5310a32cdda63cbf48.png)
**Post date:** [January 15, 2024, 5:31am UTC](https://community.dynatrace.com/t/add-these-values/43518/18 "2024-01-15T05:31:20Z")
</div>
HI, [@gbaudart](https://community.dynatrace.com/user/64996)
I need to know how to search for a desired service using tags.
Maybe I need to change something here?
```auto
serviceSelection
 ![yuval1983_1-1705296788554.png](https://global.discourse-cdn.com/dynatrace/original/3X/8/7/87a1b02143e529a549982c530e5727732fd4480f.png)
This is the code-
[https://paste.ofcode.org/3863CCfHHf3qzWB2REYYAGA](https://paste.ofcode.org/3863CCfHHf3qzWB2REYYAGA)
Could you please tell me where I can find an index or a way to debug it?
**Post date:** [January 15, 2024, 8:56am UTC](https://community.dynatrace.com/t/add-these-values/43518/19 "2024-01-15T08:56:24Z")
</div>
Hi&nbsp;[@yuval1983](https://community.dynatrace.com/user/60894)&nbsp;
In the EntitySelector command, you can filter with the desired tags like this:
```markup
input => `in("dt.entity.service", entitySelector("type(service), entityName.equals(~"${input}~"), tag("$TAG_VARIABLE")"))`
**Post date:** [January 21, 2024, 7:02am UTC](https://community.dynatrace.com/t/add-these-values/43518/20 "2024-01-21T07:02:56Z")
</div>
Thank you for your assistance.
I have a new project and need to prioritize, but I will update you once I have more information. Thank you again for your help and prompt responses.
