Alert create for Endpoint group
I have a group of endpoint with pattern in the between, these endpoints collect from OneAgent SDK.
the endpoints run as names
/irf-provider-container-reg/api/v6.4.0/party/us/customers/C-00000096205454/individuals
/irf-provider-container-reg/api/v6.8.0/party/us/customers/C-00000654654564/individuals
/irf-provider-container-reg/api/v5.0.0/party/us/customers/11656548380/individuals
Also they may not come same service because it may be incoming or outcoming call. Same endpoints can come from on two services.
I want to create the alerts for groups of endpoints - if it possible as naming a
/irf-provider-container-reg/api/v6.4.0/party/us/customers/<accountID>/individuals
I try in Key request, but it just work on specific endpoint , not group. I also try web naming rule, but it is very hard to collect group endpoints.
Anyone know how to do it, please help.
Hi there.
Thanks for posting this here in the guild forum. I would however suggest that you post this in one of the Ask channels we have on the public discussion forum. Remember: our guild is a great group - but - you only have guild members here. I therefore suggest you repost this in the other forums that can be seen by everyone in the community. One such ask channel for your question might be the https://community.dynatrace.com/t5/Alerting/bd-p/Alerting or https://community.dynatrace.com/t5/Open-Q-A/bd-p/DynatraceQandA
Andi
I will move this to Alert group. Thanks Andi
Have you tried to use Request naming rules? With the request naming you can replace the actual random <account-ID> in the endpoint with some fixed string and Dynatrace will join those request into single request per service. Then you can mark it as a key request and specify alerting for it. But still it will be defined per service.
Request naming is available per service in service settings
or globaly in Classics settings > Server-Side Service monitoring
But there you have to define them via API.
There is a nice PRO TIP about generic request naming by @Julius_Loman on regex request naming https://community.dynatrace.com/t5/Dynatrace-tips/PRO-TIP-Global-request-naming-for-REST-services/m-p/176341/highlight/true#M289
You can try to define you own regex matching that suits your case and merge your requests on services that you mark with some tag for example.
