Alert if Kubernetes daily cronjob fails
Is there a way to alert if a k8s cronjob fails? This cronjob runs once a day, if it fails we would like to have an alert. Is there an ootb metric for this type of alerting?
Hi @sivart_89,
If you have Kubernetes API integration:
Kubernetes API Monitoring - Dynatrace Docs
Have you tried or tested this built in anomaly detection setting?
or with this metric (or metric expression) you can create a metric event for alerting:
I hope it helps.
Best regards,
Mizső
