We’re monitoring process availability of few processes via declarative process grouping, if we intend to turn off monitoring for a specific process against specific OS, would be feasible to do so?
In my case, process command and executable path is common for Linux and AIX, requirement is to disable alerting only for AIX.
If you are looking to turn off monitoring you can do so a couple of different ways. One of the ways is to explicitly state which group you want to monitor by turning it off environment-wide here:
Thanks for your response. My requirement is to turn of this specific process monitoring only for AIX systems and it should stay intact with Linux. Please note that exe name and path are same for both OS.
This is where robust tagging comes into play. As you stated, you want to disable the monitoring for a given process name where the underlying OS is AIX. If you create an auto tag rule for the OS value, it can be populated from the host level and down into the PGs, PGIs, and Services. Once that is completed you can then create the Maintenance window to say suppress alert notifications for <PGName> where the tag is OS:AIX.
