Alerting when JBOSS is in suspended status
Is there way to identify if a jboss process goes into suspended state ? We would like to generate an alert when the jboss process is suspended and not responding.
Hi @susmita_k
You can do that through:
  1. creating a metric event based on the required metric, customize the configuration either depending on static or dynamic values as per the monitoring requirements.
  2. filtering and splitting by the specific JBoss process group.
  3. for dashboarding purposes, you can customize the coloring schema.
Just an example, you can tailor it as per actual scenario.
