I see the warning “If Angular 17+ is used for your application, don’t enable the Angular module.” in the app settings. I’ve read through the documentation. We moved to 17.04 month ago and we still have it enabled on all of our sites. We also have and always had Capture xmlHttpRequest(XHR) and Capture fetch() request.
Should we be concerned? What should we be looking for or dropping if having this still enabled? What if any is the problem leaving this on?
Thanks -
