Anomaly detection Threshold
Hi All,
Do you have best explanation of this configurator?
What is the best practice if we want to simply modify a response time threshold to 20sec?
Good day.
Details about the absolute and relative thresholds, as well as how to better define anomaly detection rules for Dynatrace monitored entities can be found here: Adjust the sensitivity of anomaly detection — Dynatrace Docs
Additionally, for simple, customized alerting, you can also head to ‘Custom events for alerting’ page within Anomaly Detection settings. This allows you to choose an individual metric and configure a threshold for that metric, as well as filter for particular entities and customize the alert message. Here’s a great blog post which reviews this functionality in detail: Custom time-series events for your specific use cases
Hope this helps.
-Ryan
