Hello!
There is no WhatsUp in “Integrate with other notification system”.
Does anyone knows how to integrate?
Igor
Hello!
Igor
You need to have WhatsApp business or use another service such as Twilio to send automated messages to WhatsApp. WhatsApp itself does not have any other official (free) API.
Thank you Julius! Good info to have for start. I will investigate it in more details …
If get anything interested let it know here.
The Dynatrace mobile app is not an option for you?
Good point. I actualy missed it. Will discuss with customer.
Hi guys,
Just take into your consideration that for the time being there is no way to use management zone nor alerting profiles when using the Mobile App hence the Mobile App will show all the problems.
Yos
Hi Julius,
So I guess we have to integrate Dynatrace with WhatsApp API using a custom integration via webhook URL, right?
Thanks in advance.
Elena.
can we get the dynatrace problems alerts on whatsApp
If it possible then please give the steps
