API for List of valid tags for Maintenance Window scope
As part of the Maintenance Window API functionality, in order to set the scope of a maintenance window to filter on tags, it is necessary to pass only valid tags. Is there an API method to retrieve the valid tag list, similar to generating the list that pops up in the UI?
You could probably use the topology api and then crawl through that to pull the available tags. I’m not aware of an API endpoint that just pulls that. I’d submit an RFE.
I ended up using the Host entities feed , and then transforming that into a distinct list:
var listTags = from h in Entities
from t in h.Tags
select t.Key;
_uniqueTags = listTags.Distinct().OrderBy(x=>x).ToList();
return _uniqueTags;
