I am working on a DQL query to gather and store 2 variables and then create a trending variable.Please advise if this is the best way to solve this problem.// Fetch Active problems from the last 7 daysfetch dt.davis.problems, from: now()-7d| fieldsAdd entity_tags| expand entity_tags| filter event.status == “ACTIVE”| summarize count(), alias:last7DayCount// Fetch Active problems from the 8-14 days ago| append [fetch dt.davis.problems, from: now()-14d, to: now()-8d| fieldsAdd entity_tags| expand entity_tags| filter event.status == “ACTIVE”| summarize count(), alias:last14DayCount]// Combine results into a single output| summarize sum(last7DayCount), alias:last7DayCount, sum(last14DayCount), alias:last14DayCount| fields last7DayCount, last14DayCount// Calculate trend using conditional logic with named parameters| fieldsAdd trend = if(condition: last7DayCount > last14DayCount, then: “Up”, else: if(condition: last7DayCount < last14DayCount, then: “Down”, else: “Stable”))// Display results| fields last14DayCount, last7DayCount, trend
I would suggest running a single fetch going back the full 14 days and then using summarize combined with countIf. This can be used to create two separate count, one for the last 7 days, and one for the prior 7 days (based on the start time perhaps). You can then use fieldsAdd with an if statement that compares the two counts to determine which way the trend is moving. I would also urge caution around the use of the expand command, as well as filtering on active==true in your query, as both of these might generate undesirable results depending on what you are trying to accomplish here.
