Hello!
I was looking to create tags based off Web Application Name Patterns.
I.e. Application Detection Rules
However, I’m seeing inconsistent behaviour.
When I try a Contains match on local, it fails to match against localhost
However, when I try to match against virt, it has no issues matching with test-virtualbox.
Any ideas as to why I’m seeing this inconsistency?
Thanks!
So this ‘inconsistency’ is a misnomer. Your Management Zone is looking at the Web Application Name:
Dynatrace Management Zones will not qualify the segments as the name of the web application such as the web app detection rule = <Value>
Granted, if this is a new feature that allows you to detect the criteria, then yes it should work. My only question for you would be, “When was that application active from the localhost?” Notice the blurb about that last 72 hours. Was the application transversed via that localhost in the last 72 hours?
