# AWS integration not showing application load balancers
**URL:** <https://community.dynatrace.com/t/aws-integration-not-showing-application-load-balancers/9063>\
**Category:** Cloud platforms\
**Tags:** aws\
**Created:** [November 13, 2017, 7:36pm UTC](https://community.dynatrace.com/t/aws-integration-not-showing-application-load-balancers/9063 "2017-11-13T19:36:30Z")\
**Posts on this page:** 10\
**Page:** 1
<div class="post-metadata">
**Author:** ![chris\_geebelen](https://avatars.discourse-cdn.com/v4/letter/c/7ab992/32.png) [@chris\_geebelen](https://community.dynatrace.com/u/chris_geebelen)\
**Post date:** [November 13, 2017, 7:36pm UTC](https://community.dynatrace.com/t/aws-integration-not-showing-application-load-balancers/9063/1 "2017-11-13T19:36:30Z")
</div>
Dynatrace only shows ELB’s with type classic. What should I do to get ELB’s of type application visibile in AWS screen in Dynatrace?
Kind regards,
Chris
**Author:** ![pawel\_brzoska](https://dub1.discourse-cdn.com/dynatrace/user_avatar/community.dynatrace.com/pawel_brzoska/32/18892_2.png) [@pawel\_brzoska](https://community.dynatrace.com/u/pawel_brzoska)\
**Post date:** [November 15, 2017, 7:21am UTC](https://community.dynatrace.com/t/aws-integration-not-showing-application-load-balancers/9063/2 "2017-11-15T07:21:32Z")
</div>
This is RFE on the roadmap.
**Author:** ![clarter](https://avatars.discourse-cdn.com/v4/letter/c/df788c/32.png) [@clarter](https://community.dynatrace.com/u/clarter)\
**Post date:** [February 21, 2018, 3:13pm UTC](https://community.dynatrace.com/t/aws-integration-not-showing-application-load-balancers/9063/3 "2018-02-21T15:13:27Z")
</div>
Any update on this? I went to go add our ALBs to a dashboard today and couldn’t find them. ALBs have been out since August of 2016 and even AWS is pushing everyone away from Classic ELBs.
**Post date:** [February 22, 2018, 7:55am UTC](https://community.dynatrace.com/t/aws-integration-not-showing-application-load-balancers/9063/4 "2018-02-22T07:55:39Z")
</div>
The work on that is about to start. Sorry for the delay…
**Author:** ![vikrant\_tyagi](https://avatars.discourse-cdn.com/v4/letter/v/e9c0ed/32.png) [@vikrant\_tyagi](https://community.dynatrace.com/u/vikrant_tyagi)\
**Post date:** [March 20, 2018, 6:21am UTC](https://community.dynatrace.com/t/aws-integration-not-showing-application-load-balancers/9063/5 "2018-03-20T06:21:50Z")
</div>
Hi, Any update specific to this RFE.
**Post date:** [March 21, 2018, 7:58am UTC](https://community.dynatrace.com/t/aws-integration-not-showing-application-load-balancers/9063/6 "2018-03-21T07:58:18Z")
</div>
The initial reserach starts in the current sprint.
**Author:** ![admin12](https://avatars.discourse-cdn.com/v4/letter/a/57b2e6/32.png) [@admin12](https://community.dynatrace.com/u/admin12)\
**Post date:** [April 27, 2018, 4:57am UTC](https://community.dynatrace.com/t/aws-integration-not-showing-application-load-balancers/9063/7 "2018-04-27T04:57:00Z")
</div>
A status update would be greatly appreciated. Thanks.
**Author:** ![avdveen](https://avatars.discourse-cdn.com/v4/letter/a/ed8c4c/32.png) [@avdveen](https://community.dynatrace.com/u/avdveen)\
**Post date:** [May 21, 2018, 7:34am UTC](https://community.dynatrace.com/t/aws-integration-not-showing-application-load-balancers/9063/8 "2018-05-21T07:34:44Z")
</div>
Is this the RFE you’re referring to, Pawel? [https://community.dynatrace.com/spaces/483/dynatrace-product-ideas/idea/199105/rfe-aws-application-load-balancer-monitoring-in-dy.html](https://community.dynatrace.com/spaces/483/dynatrace-product-ideas/idea/199105/rfe-aws-application-load-balancer-monitoring-in-dy.html)
Any further updates on this, ETA perhaps?
**Post date:** [May 22, 2018, 6:31am UTC](https://community.dynatrace.com/t/aws-integration-not-showing-application-load-balancers/9063/9 "2018-05-22T06:31:31Z")
</div>
Yes, that’s the same requirement. We delayed this a bit, because wanted to switch to new AWS API first, which they have just released. This change will allow lower overhead and costs on customer’s side, so it’s important for everyone. ALB/NLB support will be done just after that, I expect it to be ready in Q3.
**Post date:** [September 12, 2018, 12:55pm UTC](https://community.dynatrace.com/t/aws-integration-not-showing-application-load-balancers/9063/10 "2018-09-12T12:55:50Z")
</div>
Support for Application (ALB) and Network (NLB) load balancer types is introduced with 1.153.
