Building a dynamic login notification screen for user group(s)
Building blocks for creating mandatory dynamic inlog notification screens for users:
Design your Dashboard and export it in JSON.
Use any tool or script to modify the json to your liking, cleanup META data and add variables!
Generate an API key with the correct paramters,
for more info see:
You can automaticaly post new info on the login dashboard of users. You can even post events/info from any other tool. The sky is the limit!
Thx @joep_vd
KR Henk
Thank you​:blush: Good job!
