Bulk import of management zones from one environment to another
Hello Folks,
I have definations exported for all management zones in JSON from one environment.
Is there a way with which we can import management zones JSON on another environment in bulk?
I know, we can post JSON for each management zone from API explorer (of another environment) but I’m looking for some automated way.
AK
Hi Akshay,
I don’t think you can import them in bulk, but I created a tool that can help you.
HTH
Alonso
Hi Akshay,
I’ve done this and a lot of other configuration sync in my config management. In fact it allows you to transfer ANY dynatrace configuration from one tenant to another and a lot more!
I’ve decided to put parts of this work under GPLv3 so you can reuse it:
What this basically allows you to do is to fetch configs, store it into JSON files and then import the whole config set into other environments
