Business Flow unable to Pick all Business Events
Hi, I’m facing a situation where I’m using UAT data as Business Events, and want to link all of them up as Business flow. Currently i have around 30 business event types, all of them having data within the past 7 days.
However, when I’m selecting events in Business flow, there happens to only be able to select up to around 8 business events. Why is this happening?
Hi @rouyijee
A few things usually cause this:
  1. Bucket selection. In edit mode, Business Flow only collects event.type and event.provider values from the buckets you’ve selected. If your UAT events go to a custom bucket, add it in the flow’s settings and they should appear.
  2. Per-step limit. You can add up to five events per step, so with ~30 event types you’ll need to spread them across several steps rather than one.
  3. Event naming. The dropdown lists event.type/event.provider combinations found in your environment. Events must have a populated event.provider and event.type to be selectable.
To check what exists, run this in a Notebook and compare it to the dropdown:
fetch bizevents, from:-7d
| summarize count(), by:{dt.system.bucket, event.provider, event.type}
Sujit
