# Calculating throughput of AWS Lambda
**URL:** <https://community.dynatrace.com/t/calculating-throughput-of-aws-lambda/41752>\
**Category:** Cloud platforms\
**Tags:** aws, lambda\
**Created:** [September 23, 2023, 10:21am UTC](https://community.dynatrace.com/t/calculating-throughput-of-aws-lambda/41752 "2023-09-23T10:21:34Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![Anidarsha](https://avatars.discourse-cdn.com/v4/letter/a/f04885/32.png) [@Anidarsha](https://community.dynatrace.com/u/Anidarsha)\
**Post date:** [September 23, 2023, 10:21am UTC](https://community.dynatrace.com/t/calculating-throughput-of-aws-lambda/41752/1 "2023-09-23T10:21:34Z")
</div>
How to calculate average throughput of a lambda for selected time interval .
What is the purpose of resolution metric.&nbsp; When the average throughput is calculated for time interval 5 mins , what value should be set as resolution. By default it is taking 1 hour and calculated tps is comparatively less than expected.
**Author:** ![ChadTurner](https://dub1.discourse-cdn.com/dynatrace/user_avatar/community.dynatrace.com/chadturner/32/161_2.png) [@ChadTurner](https://community.dynatrace.com/u/ChadTurner)\
**Post date:** [February 12, 2024, 8:43pm UTC](https://community.dynatrace.com/t/calculating-throughput-of-aws-lambda/41752/2 "2024-02-12T20:43:40Z")
</div>
If your GTF is looking at a 5 min window, you can select the resolution to be 1 min and you will get 5 data points, or 5 Mins with 1 data point, anything higher will only give you 1 data point. Really depends on your use case and what you want to look at. Do you need metrics at a 1 min period or a 5 min overall period?
