# Can Dynatrace send multiple rootcause nodes in a single problem?
**URL:** <https://community.dynatrace.com/t/can-dynatrace-send-multiple-rootcause-nodes-in-a-single-problem/33317>\
**Category:** Alerting\
**Tags:** problem-detection, problems-classic\
**Created:** [November 18, 2021, 7:06am UTC](https://community.dynatrace.com/t/can-dynatrace-send-multiple-rootcause-nodes-in-a-single-problem/33317 "2021-11-18T07:06:10Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![sreedharm](https://avatars.discourse-cdn.com/v4/letter/s/d07c76/32.png) [@sreedharm](https://community.dynatrace.com/u/sreedharm)\
**Post date:** [November 18, 2021, 7:06am UTC](https://community.dynatrace.com/t/can-dynatrace-send-multiple-rootcause-nodes-in-a-single-problem/33317/1 "2021-11-18T07:06:10Z")
</div>
hi All,
I would like to know if Dynatrace can send multiple root cause nodes in single problem? Meaning there can be two events where the events might have caused a problem/disruption to the same applications/services. In this case node 1 and node 2 are both root cause nodes for my service being down. Will Dynatrace send them in single problem? Since I dont see how the structure for that kind of problem will be in the problems API I’m reaching out here to see if anyone has come across/seen such incidents?
Sreedhar
**Author:** ![Babar\_Qayyum](https://dub1.discourse-cdn.com/dynatrace/user_avatar/community.dynatrace.com/babar_qayyum/32/13620_2.png) [@Babar\_Qayyum](https://community.dynatrace.com/u/Babar_Qayyum)\
**Post date:** [November 18, 2021, 7:21am UTC](https://community.dynatrace.com/t/can-dynatrace-send-multiple-rootcause-nodes-in-a-single-problem/33317/2 "2021-11-18T07:21:56Z")
</div>
Hello&nbsp;[@sreedharm](https://community.dynatrace.com/user/46069)
The root-cause section of the problem details page displays up to three root-cause candidates, with **candidates aggregated into groups of vertical topologies**. This enables you to quickly review outliers within affected service instances or process clusters.
If several components of your infrastructure are affected, a&nbsp; **Visual resolution path** &nbsp;is included in the&nbsp; **Root cause**. The visual resolution path is an overview of the part of your topology that has been affected by the problem.
Please have a look at the below link for more insight.
> **[Root cause analysis concepts](https://docs.dynatrace.com/docs/dynatrace-intelligence/root-cause-analysis/concepts)**
> Get acquainted with root cause analysis concepts.
Babar
