Can I transfer the VM Dynatrace node to another network using vCenter?
Can I transfer the VM Dynatrace managed to another network using vCenter?
I have Managed (not offline) installation.
If I move the vm in another subnet then nothing breaks ?
If IP address remains same and network connectivity to there nodes (if there are any) it should work.
Otherwise you need to follow one of the steps described in our migration guide:
Migrate a cluster
I believe in your use case the only option is to use backup and restore in the target subnet.
Thank you for answer
I have not had monitoring data yet.
I installed dynatrce , but the networkers want to migrate it to another segment. It will be the same vm but it will transfer (I do not create a new machine)
Interested in a question at me that the license after migration was not blocked
If you have nothing yet and the IP will change - maybe it’s just easier to reinstall.
1. Remove a cluster and free the license: Remove a cluster node
2. Install in a new place.
If IP will be same - it should work.
VM will be same , simple it will be migrate to another VLAN ( another ip network)
Do I need re-install Dynatrace cluster ? ( I have not offline mode )
If IP changes - you have to to reinstall or migrate.
