Can we manually run Synthetic browser clickpath directly (i.e., not using script playback GUI) from Linux AG machine?
looking for a way of manually triggering browser clickpath monitor from a private location (AG on Linux) to troubleshoot target system response (similarly to using curl for manual triggering of http monitor).
Hi @yuri_v
Did you try the Manually add clickpath events button?
Which allow you to add events rather than record them
Just make sure your AG is compile with the prerequisites of Linux and Chromium
HTH
Yos
