# Can you create a custom alert for a metric and applied it to multiple dimensions?
**URL:** <https://community.dynatrace.com/t/can-you-create-a-custom-alert-for-a-metric-and-applied-it-to-multiple-dimensions/19013>\
**Category:** Alerting\
**Tags:** extensions, problems-classic\
**Created:** [April 6, 2020, 4:20pm UTC](https://community.dynatrace.com/t/can-you-create-a-custom-alert-for-a-metric-and-applied-it-to-multiple-dimensions/19013 "2020-04-06T16:20:30Z")\
**Posts on this page:** 7\
**Page:** 1
<div class="post-metadata">
**Author:** ![alonso\_decosio](https://avatars.discourse-cdn.com/v4/letter/a/bbe5ce/32.png) [@alonso\_decosio](https://community.dynatrace.com/u/alonso_decosio)\
**Post date:** [April 6, 2020, 4:20pm UTC](https://community.dynatrace.com/t/can-you-create-a-custom-alert-for-a-metric-and-applied-it-to-multiple-dimensions/19013/1 "2020-04-06T16:20:30Z")
</div>
We have a JMX plugin that is importing metrics from JMS and is splitting them by queue name, and we only need the alert for some of them. Can we define multiple queues (dimension) on the same alert?
**Author:** ![Julius\_Loman](https://dub1.discourse-cdn.com/dynatrace/user_avatar/community.dynatrace.com/julius_loman/32/51_2.png) [@Julius\_Loman](https://community.dynatrace.com/u/Julius_Loman)\
**Post date:** [April 10, 2020, 8:28pm UTC](https://community.dynatrace.com/t/can-you-create-a-custom-alert-for-a-metric-and-applied-it-to-multiple-dimensions/19013/2 "2020-04-10T20:28:05Z")
</div>
If you are asking about the “Custom events for alerting” feature, I think it’s not possible. For dimension based alerts, you need to specify the dimension (no rules such as matches or begins with are possible). Thus you will need to set up a separate alert rule for each dimension (queue name) you need.
But this sounds like a good RFE candidate.
**Author:** ![wolfgang\_beer](https://dub1.discourse-cdn.com/dynatrace/user_avatar/community.dynatrace.com/wolfgang_beer/32/14717_2.png) [@wolfgang\_beer](https://community.dynatrace.com/u/wolfgang_beer)\
**Post date:** [April 14, 2020, 6:16am UTC](https://community.dynatrace.com/t/can-you-create-a-custom-alert-for-a-metric-and-applied-it-to-multiple-dimensions/19013/3 "2020-04-14T06:16:50Z")
</div>
Either you can alert on ‘All’ available dimensions, this is the default in custom alert config screen or you can select one specific dimension. If you need to alert on more than one selected dimension you have to create a second configuration.
**Author:** ![kalle\_lahtinen](https://avatars.discourse-cdn.com/v4/letter/k/bb73d2/32.png) [@kalle\_lahtinen](https://community.dynatrace.com/u/kalle_lahtinen)\
**Post date:** [April 16, 2021, 10:43am UTC](https://community.dynatrace.com/t/can-you-create-a-custom-alert-for-a-metric-and-applied-it-to-multiple-dimensions/19013/4 "2021-04-16T10:43:01Z")
</div>
Hi Wolfgang,
We are monitoring a JMS service with 700 queues. So I suppose I’ll then just create 700 custom alerts, wish me luck! 🙂 Nah, I guess I need to think about some other solution… I wonder if Monaco&nbsp;would help here? I would somehow need to populate the values for each 700 queues, though…
When defining the JMX plugin, I can split the data by dimension (by queue). But then I can’t alert with the same idea. So I can monitor… but I can’t alert. That’s a shame.
**Author:** ![payal\_bid](https://avatars.discourse-cdn.com/v4/letter/p/cdc98d/32.png) [@payal\_bid](https://community.dynatrace.com/u/payal_bid)\
**Post date:** [February 26, 2024, 9:44am UTC](https://community.dynatrace.com/t/can-you-create-a-custom-alert-for-a-metric-and-applied-it-to-multiple-dimensions/19013/5 "2024-02-26T09:44:48Z")
</div>
Hey&nbsp;[@kalle\_lahtinen](https://community.dynatrace.com/user/25049)&nbsp;,
Did you get any resolution for the query? I have the same ask.
Thanks in Advance!
**Post date:** [February 26, 2024, 9:59am UTC](https://community.dynatrace.com/t/can-you-create-a-custom-alert-for-a-metric-and-applied-it-to-multiple-dimensions/19013/6 "2024-02-26T09:59:50Z")
</div>
Sorry, it’s been ages since I worked on that case… at least at the time I don’t think the metric events could be split based on the dimension, and we had to follow the queues only via dashboards. However that was 3 years ago, and Dynatrace has gone through several major updates since then. It’s quite possible that today it actually is doable. But I don’t have any similar sample environment where I could test it at the moment, so I’m not certain of course.
**Post date:** [February 26, 2024, 10:05am UTC](https://community.dynatrace.com/t/can-you-create-a-custom-alert-for-a-metric-and-applied-it-to-multiple-dimensions/19013/7 "2024-02-26T10:05:47Z")
</div>
Okay&nbsp;[@kalle\_lahtinen](https://community.dynatrace.com/user/25049)&nbsp;,
Thanks for your quick response.
We have a scenario regarding queues where we have a the metric key created on jmx plugin and we want to be alerted whenever there’s a breach in the threshold. However, creating over 150 custom alerts isn’t feasible due to the static threshold.
