Hi Team,
Any idea how to plot forecast graph of infra metrics (cpu, memory and disk).
I have seen in some latest product videos that forecasting feature would be available in the latest new transformed product.
I tried using latest Notebook feature but couldn’t find how to get the forcast data.
Suresh
Thanks @Mizső for your response. I can find the forecast option now.
However, when I click on forecast then I am getting error message “Davis analyzer forecast failed.”
5th row is getting added to the query automatically.
Any idea what is happening here.
I am getting the same error as well
Sorry guys, I did these charts 2 or 3 weeks ago. It worked that time.
Now I am in the same situation. It does not work for me also. ☹️
Hey @SureshThakur
The 5th line is added on purpose so that only the line you selected is forecast. We currently don’t support forecasting of multiple lines.
@SureshThakur, @Ahmed_Khaled:
I tried to reproduce the failed forecast on a production tenant with the same query
1) On what tenant are you trying to run the forecast?
2) What timeframe did you select?
Thanks for the response.
I am using demo (guu84124) tenant - https://{environmentid}.apps.dynatrace.com/
Timeframe selected was 7 days and 15 days
Hey @LindaGratzer I am using guu84124, timeframe 30 days
We think the failing forecast might be a permission issue. We are adapting the required permissions
Hi @LindaGratzer . I tried the same query in my own environment where I have full admin access and it is still failing with same error
@Ahmed_Khaled @SureshThakur
we have updated some permission scopes on our side. Can you logout and login and try to run it again?
Hello @LindaGratzer I tried and still got the same error.
@SureshThakur @Ahmed_Khaled
can you include a screenshot and the data of the network request and response?
- open the developer console
- go to the network tab
- add ‘/analyzers’ in the filter expression
- execute the forecast
- select the dt.statistics.GenericForecastAnalyzer:execute request
- copy data from the tabs: payload, data (most important info: requestId in the response)
Please below screenshot. I can see the request is failing with 403.
Hi @LindaGratzer I have attached the screenshot as requested.
403 indicates that you are missing permissions/scopes reading buckets or executing the analyzer API.
Sadly, I cannot help you here. you should open an RFA with someone from account management
Thanks @LindaGratzer - I tried in my own environment and it is working there. Appreciate your continues support on this.
Is this forecasting feature available on both Managed and SaaS?
Thank you in advance.
Hi @agylpradipta,
Only on SaaS Gen3 which was launched in April.
Best regards,
Mizső
