Hello
there are pages where i can see many add to cart icons. i need to calculate the count wherever the icon appears. how does it possible in dynatrace managed?
thanks
Ram
Hello
thanks
Ram
If you are asking about if there is functionality to count a number of certain elements in a web page, then the short answer is no, that’s not possible directly.
If you, however, can modify your application code, you can push this information using the Dynatrace RUM API - dtrum.addActionProperties() and define this property for your web application in Dynatrace.
Another option would be to count it from the server-side using request attributes, but this highly depends on your application design.
