I have a dashboard where I am fetching the number of problems per application. 3 of the 4 columns are left-aligned, but the “Problems” column is right-aligned. Is there a way to just center-align everything using DQL or something?
Hi! Hope all is well.
By the looks of it I can’t seem to find a way to center the columns within a dashboard. My suggestion would be to use the resize tool to make the columns smaller so that it simulates the center alignment. I explored the different column types and the closest was using a markdown column. Although you would need to use it in combination with html to “center” it. It does look like this has been brought up and may be a future product idea.
Hope this helps!
@sjena7810 feel free to submit a product idea.
If you could share a link to the ready idea under this post, users would be grateful. ![]()
