Hello
1/
I add the INITPARM parameter in the SIT of few CICS regions.
Here follows the syntax.
************ LOGGING DYNATRACE ********************
INITPARM=(ZDTPLT=‘MEPC[,F]’)
As i specified F as Fine option of logging, I expected that every initialization of 5 minutes cycle of DTAX transaction would be written in the MSGUSER.
ZDTP002F fine 01/28/2021 09:57:20 ZDTP002F DTAX 5 minutes cycle begin
ZDTP003F fine 01/28/2021 09:57:20 ZDTP003F AgentID = FFD887F6
ZDTP005F fine 01/28/2021 09:57:21 ZDTP005F DTAX 5 minutes cycle end
I also expected to receive the following fine messages at initialization :
ZDTP010F fine 01/28/2021 09:52:15 ZDTP010F Pre initialize_msg zDC Agent ID: 00000000
ZDTP008F fine 01/28/2021 09:52:17 ZDTP008F INIT completed with rc:0
I managed to receive these message when i enter the option ‘Fine’ on the Dtax view.
Could you explain me why fine messages aren’t written when mentioned in the initparm SIT parameter ?
2/
I looked for a “initialization complete” or successful, kind of information message in the msguser for Dynatrace environment, and i couldn’t find one.
Could i considered message ZDTP020I as an information that the environment has successfully been initialized ?
Is there a message more proper for initialization complete cics should receive?
If not would it possible to write one in the cics log?
thanks in advance for your reply ?
Regards
Sébastien Arjo
