Close problem only when {dims:units} is 0
timeseries v = avg(unexpecteddowntime), by: {site, unit}
| summarize {
site_series = avg(v[]),
units = collectDistinct(unit)
}, by: {site, timeframe, interval}
| filter arrayMax(site_series) > 30
| fieldsAdd units_str = toString(units)
Using this in Davis Anomaly Detector for creating alerts site wise, and having {dims:units} in the description but the problem is closing and opening a new instance whenever there is change in the {dims:units}. I only want to close the alert {dims:units} is 0
If you are using this query, and in the Davis Anomaly metric event you’re using something like {dims:units} in the description. In Dynatrace, whenever a dimension (anything referenced via {dims:…}) changes, Davis treats it as a new problem instance.
So when the list of units changes even slightly: Old problem is closed and New problem is opened
That’s why you see constant open/close cycles.
If I correctly understand, you want to open one problem per site.
So, do not use {dims:units} anywhere (especially in description).
That makes units part of the problem key.
Use units only as a field, not a dimension.
Drive open/close behaviour via DQL:
  • Alert only when units_count > 0
  • Problem auto-closes when units_count = 0
Try this:
| summarize {
    units = collectDistinct(unit),
    units_count = countDistinct(unit)
| filter units_count > 0
units_count > 0 → only then the metric event is evaluated as violating
When units_count becomes 0, the violation stops → Davis will close the problem
Then in metric event use site as a dimension, like this:
Site: {dims:site}
Affected units: {fields.units_str}
the filter that you see in the problem is not part of my query but its getting added and the reffered fields.unit_Str is not getting the field value referred , could you pls help here @t_pawlak
I don’t see such thing as “fields” in the doc (Anomaly detection configuration — Dynatrace Docs) - I also tried to use it in my Davis Anomaly Detector but results were the same like for @O11y_Noob
Can you please give the source from which you got this info?
Best Regards,
Patryk
It looks like the additional filter (…) you see in the problem view is not coming from your DQL. Davis automatically adds a filter for the concrete time-series that triggered the event (based on the dimensions/placeholders used in the metric event).
Also, my previous suggestion with {fields.units_str} was misleading – fields.* placeholders are not supported in the event template, which is why you don’t see the value there.
In practice this means that if you reference units / units_str in the title/description, Davis will “pin” the problem to that exact value and will open/close a new problem every time the list of units changes. To have one problem per site, keep units only inside DQL (for filtering/logic) and use only {dims:site} (and standard placeholders like {value}) in the event template.
the team wants to see the unit names in the problem ticket , how can i include it in the problem ?
