Hi Team,
Need your help here..
We don’t see command line args under properties and tags for POSTGRE Instances. Requirement is to create a separate process group using command line args. We would like to understand how to enable command line args for POSTGRE Instances.
Mukesh
@PacoPorro DT_CLUSTER_ID and DT_NODE_ID are for deep monitored processes with code module injected. Postgresql is not one of them. For this, @nicemukesh needs declarative process grouping instead.
Thanks for your response…
@Julius_Loman Dynatrace creates multiple process instances with same name Postgresql . Actually, we want to distinguish process instances using command line arg of process and it is not being captured by Dynatrace under Properties and tags.
command line arg
D /u01/app/postgres/postgres1/pg15/data/pgbase
D /u01/app/postgres/postgres2/pg15/data/pgbase
Can you please let me know why it is missing and how it can be captured in by Dynatrace
Mukesh
