Hi I am bit confused about OneAgent communication to Dynatrace Managed server. It communicate on port 443 or 8443.
The OneAgents will communicate with the Server Nodes over port 8443. Port 443 is used to access the user interface in your browser:
James
If I am using security gateway, Does it also communicate to server over 8443 or 443.
Agents communicate with Security Gateway on 9999. See the architecture diagram here:
if we install a Security Gateway into our DMZ, we do not allow connections into the world.
Which connections into the word are needed? Is it enough to allow connections to port *:80 and *:443 in the wide wide internet or do we need specific connections?
Best regards,
Jan
