If you use Calico to handle or restrict network connections, you might experience connectivity issues, such as:
- The operator, webhook, and CSI driver pods are constantly restarting
- The operator cannot reach the API
- The CSI driver fails to download OneAgent
- Injection into pods doesn’t work
If you experience these or similar problems, use our GitHub sample policies for common problems.
For the
activegate-policy.yamlanddynatrace-policies.yamlpolicies, if Dynatrace Operator isn’t installed in thedynatracenamespace (Kubernetes) or project (OpenShift), you need to adapt the metadata and namespace properties in the YAML files accordingly. -
The purpose of the
agent-policy.yamlandagent-policy-external-only.yamlpolicies is to let OneAgents that are injected into pods open external connections. Onlyagent-policy-external-only.yaml -
