Conversion rate and converted sessions
I have defined multiple goals,
But in the metrics there is only one,
Can somebody explain why?
KR Henk
The Conversion metric that you have selected will look at goals across the environment, all the apps. You can further filter it down to a specific app but you will get the overall average across your X amount of goals on the app. Read more about it here:
We use the Top Conversion Goals Tile and it lists the top 5 per the application:
