Converting a string variable (1m, 1h, 1d) for use in interval
I have created a variable group_by in Dashboards/Notrbook to be able to group the result of a query. But I don’t know how to transform this string into a valid value:
fetch events
| filter event.kind == "DAVIS_PROBLEM"
| summarize {count = count(),event.status_transition = takeLast(event.status)}, by: {status = event.status_transition,`interval` = bin(timestamp, $group_by)}
I haven’t seen how I can do that in the documentation: DQL functions — Dynatrace Docs
Many thanks
Hi @Duran_Narbona
There is a similar example in our help: Add a variable to a dashboard — Dynatrace Docs
Just add 2 variables to dashboard, one for resolution and one for unit.
Then the query can look like this:
fetch events
| fieldsAdd toDuration(multiplier)
| summarize {count = count(),event.status_transition = takeLast(event.status)}, by: {status = event.status_transition,`interval` = bin(timestamp, duration($resolution, unit:$unit))}
Best,
Sini
