i need Create Dashboard to check metrics [system.load.average.“1m”] for all the PODS running under namespaces on my production environment.
Dashboard should contain:
1. POD. count per namespace & deployment (example - 20 pods in (prod namespace)
2. Load avg of all pod under specific deployment :
3.Load avg per pod view.
i don’t have access to create custom dashboard
Hi @vikrambisht
You need these permissions in Dynatrace to create Dashboards.
Ask your Dynatrace administrator to grant the required permissions and you should be able to set it up
HTH,
André
ok let me check for these permissions
hi,
When checking the metric “system_load_average_1m” without any management zone, the metric itself is being captured.
But with selecting the management zone i can see no data
