I need to create one log metric from fields of the table that generate the log that was ingested by API
I created the custom atribute, and i created the metric extraction,
but i can’t see the metric from Data explorer or from metrics
Could you help me to know if i need another process or how can i see or create the metric please?
Best regard.
Hi @DAVID_MTZ
Could you please share the custom attribute configuration too?
I usually count log patterns: first creating a processing rule → parse out the requested pattern, creating a custom attribute from it and create a log metric with occurence of log records and I use the custom attribute as a dimension.
I hope it helps.
Best regards,
Mizső
Best regards,
Mizső
Hi Mizső
Thanks for the help and the aswer, i send you the configuration about the custom attributes:
The configuration is the same for all the custom attributes
I will do the procedure that you comment us :
