Dashboard - pie chart with HTTP status code distribution
Context:
There is a service that is integrated into Dynatrace and appears under the ‘Service’ category. That particular service is making HTTP calls to an endpoint that is not monitored by Dynatrace.
Problem:
I would like to create a dashboard containing different kinds of charts related to the service interaction with the endpoint itself. I would like to create a pie chart that contains the HTTP status codes returned by that particular endpoint during a time period (last 24 hrs).
How can I create the pie chart? I did not find a useful metric that would help me achieve this.
Thank you
Hi, @theAsker , good day.
You can make the call to the non monitored endpoint as a key request (Monitor key requests in Services Classic — Dynatrace Docs), then you can use the keyrequest metrics (Built-in classic metrics — Dynatrace Docs) to create the dashboard.
You can also work with Multidimensional Analysis, and create calculated service metric if the builtin metrics are not enough. Multidimensional analysis — Dynatrace Docs
Try and let us know.
Thank you for the answer.
When looking at the key requests metrics I can only see an aggregation of status codes (number of 4xx, number of 5xx etc), I would like to have a pie chart with the distrbituion of all status codes. Is there a way to capture the actual http status code received?
@theAsker, you can use the Multidimensional Analysis to achieve this:
First you create a view using the HTTP Status as dimension.
Then you create a calculated service metric.
Finally, you can use the metric to create your tile and pin to a dashboard.
Why pay to create a custom metric for something that is already stored and viewable in multidimensional analysis ?
There is no logic behind it ?
Just a lack of a dimension on service/service_method metrics !
