I would like to know if there is a way to generate dashboards of total DEM units and Hosts Units. What metric should I use?
Hi @bruna
Could you please check it on the demo live environment?
Licensing Overview 2.0 - Dynatrace Demo Live: Demo Live - Dynatrace :
You can find any other useful dashboards here.
I hope it helps.
Br, Mizső
Check out BizOps Configurator - Licensing Overview. Winner
Can I get access to environment to see if any dashboards that would be helpful to us?
Anyone from a partner account can register in the Partner portal, instructions attached, and then use the same credentials on the Demo env or any other Dynatrace platform.
Best regards,
Mizső
How to access the Dynatrace Partner Portal.pdf (257 KB)
Oh, we aren’t a partner ![]()
Hi @Kenny_Gillette,
Do not be sad, attached. You can play with it;-)
Best regards,
Mizső
Licensing Overview 3.0.zip (4.87 KB)
thanks much. Looks like one I pulled from BizOps. Glad we aren’t missing anything. Appreciate it!
