Default behavior of web checks
According to the documentation, I saw that “Browser monitors alert you when your application becomes inaccessible or when baseline performance degrades significantly”. Is Dynatrace considering that the web check fails if the HTTP response code is different of a 2XX type ?
Hi Thierry,
yes, a browser monitor (formerly web check) also fails for status codes between 400 to 599.
Kind regards, Philipp
Hi Philipp,
Thanks for the reply. I am wondering if it will be possible to specify a range of HTTP status code for validating a specific webcheck in the next releases ?
That is correct Thierry. Dynatrace’s browser monitors are flagged as failures if a typical HTTP error status code is returned (coded 400-599).
What is your use case here? Are you responding with a not-failure status code for failures? Or vice versa?
Hayden
Hello Hayden,
I would like to define a specific range of status code for failures just like “Services” where we can set it in the “Service settings”. Is this kind of feature planned in the next releases ?
