Determine which incoming connection is using the most bandwidth
When viewing a host I can see all incoming connections, but I have no way to rank these. Is there a way to show which incoming connections are using the most bandwidth, or at least which incoming connections are the most active based on number of connections of time period (e.g. last 2 hours).
Thanks!
Hi @david_hmorgan
You can go Analyze Process Connection and see in the details Transfer for each connection.
You can also select the appropriate metrics on Data Explorer and do splitting by host or application process.
Radek
