Difference between the dsfm and builtin count for user actions
Dear All,
Why is there a difference in per-minute count between the dsfm and builtin metrics for user actions per minute?
The dsfm metric count does not change even with the maximum and sum aggregations.
Babar
Hi @Babar_Qayyum
Differences in the number of user actions per minute between the DSFM metrics and the built-in metrics in Dynatrace may be due to several factors. One such factor could be the way the data is aggregated, the latency time or the definition and scope of the metrics. In general, these metrics show the same data, but small deviations may be visible.
Radek
Hello @radek_jasinski
Thank you for your comments.
I checked almost all the factors and different timeframes.
Babar
