In most of my extensions, I use requests to the AG localhost, using the API for several use-cases.
Because AG’s don’t typically have valid certs, I use the verify=False parameter to force not checking cert validity when communicating with AG.
In EF1, I had the following entries in the log files:
2024-10-09 18:28:01.190 UTC WARNING [Python][14120372674404520656][XXXXXX][140651756611328][ThreadPoolExecutor-0_1] - [write] /var/lib/dynatrace/remotepluginmodule/agent/runtime/engine_unzipped/site-packages/urllib3/connectionpool.py:1061: InsecureRequestWarning: Unverified HTTPS request is being made to host 'localhost'. Adding certificate verification is strongly advised. See: https://urllib3.readthedocs.io/en/1.26.x/advanced-usage.html#ssl-warnings
warnings.warn(
In EF2, I now have:
[9d149e58-ac16-3f82-afa1-3e262574cdd5][-1571001820422410953][3642652][err]/var/lib/dynatrace/remotepluginmodule/agent/runtime/extensions/python_venvs/XXXXXX/lib/python3.10/site-packages/urllib3/connectionpool.py:1099: InsecureRequestWarning: Unverified HTTPS request is being made to host 'localhost'. Adding certificate verification is strongly advised. See: https://urllib3.readthedocs.io/en/latest/advanced-usage.html#tls-warnings
[9d149e58-ac16-3f82-afa1-3e262574cdd5][-1571001820422410953][3642652][err] warnings.warn(
What was a WARNING before turns out to be an ERROR now. And it messes up log analysis.
I would say that this is a consequence of moving from python 3.8 to 3.10, but can someone confirm?
