Disable a Sensor on Agent
Is it possible to disable a sensor on an Agent (like in Appmon)
If you have to many useless database calls in Dynatrace, it would be nice to turn off the java.odbc sensor (-;
KR Henk
Have you seen the https://www.dynatrace.com/support/help/shortlink/troubleshoot-deep-monitoring?
It’s located in Settings → Server side monitoring → Deep monitoring. You can turn off sensors globally and  on process group level.
You were faster than me (-; thanks for your reply.
