Disable Runtime Vulnerability Analytics on a Management group
New user to Dynatrace, how do we disable Runtime Vulnerability Analytics on a specific Management Group?
Thank you.
Hi @bmolinebass ,
You can do it on this way:
Doc:
- Application Security FAQ — Dynatrace Docs
- Monitoring rules - Third-party Vulnerability Analytics — Dynatrace Docs
Hope it helps.
Elena.
Thank you!
