Where does Dynatrace get the 80% errors from, sometimes this number changes per minute?
KR Henk
From the network monitoring module and does it by network packet capture.
Further to what Julius already mentioned, the value seen on the tab, is the last captured value, meaning if you see 80%, that’s the last seen value - it is not an average or similar across the timeframe.
To my knowledge, the % is calculated based on the total nr of DNS queries, divided by the nr of errors/failures. Hence: if you had 5 queries, and 4 resulted in NXDomain(3) errors, that’s 80% errors.
Hi Julius,
Sorry about the unclear question, my mistake. I should have asked something like how is this number calculated , or something like that…
Thanks for your fast reply!
KR Henk
