Do Dynatrace provide any Extension/Capability to view low level CPU metrics
Is there anything available from Dynatrace that can show CPU data at a low level such as Frequency, core temperature etc Something similar to this product:
HWiNFO Sofware
Hi @D_Miller,
Short answer: no, not out of the box.
Dynatrace does not provide low-level hardware metrics like:
  • CPU frequency
  • Core / package temperature
  • Fan speed, voltage, power sensors
Tools like HWiNFO read directly from hardware / BIOS sensors, which is outside the scope of Dynatrace OneAgent.
What Dynatrace does provide natively:
  • CPU usage (host, process, container)
  • Load, CPU states (user/system/iowait, etc.)
  • CPU throttling for containers
These are OS-level metrics, not hardware sensor data.
If you really need hardware telemetry in Dynatrace, the only options are:
  • Use vendor hardware extensions (e.g. Dell iDRAC / Redfish from Dynatrace Hub)
  • Ingest custom metrics from external tools (Telegraf, Prometheus, scripts) into Dynatrace
Best regards,
