# Do sfm/dsfm metrics/logs consume DDUs?
**URL:** <https://community.dynatrace.com/t/do-sfm-dsfm-metrics-logs-consume-ddus/40263>\
**Category:** Open Q&A\
**Tags:** self-monitoring, licensing\
**Created:** [June 18, 2023, 4:06pm UTC](https://community.dynatrace.com/t/do-sfm-dsfm-metrics-logs-consume-ddus/40263 "2023-06-18T16:06:22Z")\
**Posts on this page:** 4\
**Page:** 1
<div class="post-metadata">
**Author:** ![AntonioSousa](https://dub1.discourse-cdn.com/dynatrace/user_avatar/community.dynatrace.com/antoniosousa/32/50_2.png) [@AntonioSousa](https://community.dynatrace.com/u/AntonioSousa)\
**Post date:** [June 18, 2023, 4:06pm UTC](https://community.dynatrace.com/t/do-sfm-dsfm-metrics-logs-consume-ddus/40263/1 "2023-06-18T16:06:22Z")
</div>
I have tried to find in the documentation if sfm/dsfm metrics & logs consume DDUs, but have not been able to find it.
I have the impression that they don’t, but would like to confirm?
**Author:** ![Fin\_Ubels](https://dub1.discourse-cdn.com/dynatrace/user_avatar/community.dynatrace.com/fin_ubels/32/18008_2.png) [@Fin\_Ubels](https://community.dynatrace.com/u/Fin_Ubels)\
**Post date:** [June 18, 2023, 10:58pm UTC](https://community.dynatrace.com/t/do-sfm-dsfm-metrics-logs-consume-ddus/40263/2 "2023-06-18T22:58:43Z")
</div>
Hey Antonio,
For metrics you can see which ones do consume DDUs allowing you to rule out DSFM ones from consumption. You can do that 2 ways, either on the consumption page detailing DDU usage or using the&nbsp;builtin:billing.ddu.metrics.byMetric metric.
As for the logs, are you referring to the ones in the dt.system.events bucket?
**Post date:** [June 18, 2023, 11:04pm UTC](https://community.dynatrace.com/t/do-sfm-dsfm-metrics-logs-consume-ddus/40263/3 "2023-06-18T23:04:47Z")
</div>
Neat trick, that of “builtin:billing.ddu.metrics.byMetric”
Relative to the logs, I’m referring to:
log.source=“dsfm”
**Post date:** [June 19, 2023, 1:22am UTC](https://community.dynatrace.com/t/do-sfm-dsfm-metrics-logs-consume-ddus/40263/4 "2023-06-19T01:22:29Z")
</div>
Using the same method but for logs, it appears that when using classic logs, dsfm logs don’t consume DDUs. The metric being builtin:billing.ddu.log.byDescription and then also the same info can be found on consumption page again. Using&nbsp;builtin:billing.ddu.log.byEntity you can also see where consumption comes from. I have some dsfm logs in my environment and they do not appear to contribute at all, neither showing in the consumption page or on the billing metrics.
