Downgrade Dynatrace Cluster
We want to roll back from version 1.208 to 1.206, is it possible?
We have to do this because of company regulations, not because Dynatrace 1.208 has a problem.
Thanks.
Andre
Hi Andre,
Just consulted this with Managed developers and no - this is not possible.
Once a cluster has been upgraded, database schema version changes that cannot be easily rolled-back. So, no it’s not supported per se.
The only option is:
1. Request a previous installer version and install from scratch.
2. Use backup, from the time before the upgrade and restore the cluster.
Hi Karolina,
Thanks for the confirmation :slightly_smiling_face:
Hi Radoslaw,
Thanks for the option, I will consider it in the future upgrade :slightly_smiling_face:
