Eyad
February 27, 2025, 7:41pm
1
hi all, i am trying to do Monthly Problem Count and ServiceNow Ticket Count Over the Last 4 Months in one tile.
fetch dt.davis.problems
| summarize TotalProblemMonthly=count(), by:{Month = formatTimestamp(timestamp, format: “MM-yyyy”)}
| join [fetch dt.davis.problems
| filter matchesPhrase(labels.alerting_profile,“ServiceNow”)
| summarize ServiceNowTickets=count(), by:{Month = formatTimestamp(timestamp, format: “MM-yyyy”)}], on:{Month}
the result coming out not sorted i want to sort it based on a month, however if i use sort command will not use the year ad well which is a problem. look at the result image. any recommendation to fix the query to sort it?
Try putting the year first, and you don’t need to do the join.
ServiceNowTickets=countIf(matchesPhrase(labels.alerting_profile, “ServiceNow”)),
by:{Month = formatTimestamp(timestamp, format: “yyyy-MM”)}
| sort Month desc
Eyad
February 27, 2025, 8:15pm
3
Perfect!, my other question. why it says line graph is unsuitable. if i want the results in graph.
You should use rounded timestamps, not string representation. Also to do proper bar chart it is better to use timerange so single bar spans the time it applies to:
| summarize { TotalProblemMonthly=count() , ServiceNowTickets=countIf(matchesPhrase(labels.alerting_profile, "ServiceNow")) },
by:{ timeframe=timeframe( from: timestamp@M, to: timestamp@M+1M ) }
| sort timeframe desc
I used time alignment operators: DQL operators — Dynatrace Docs .
Result look like this:
