DQL query for SSL certificates - Notebooks
Hi there,
I need help querying SSL certificates with exp_days == 30 and set that as warning and exp_days == 10 critical
Hi @Maelam,
It is not a Notebook but you can try it and use the created metric information on your Notebook.
SSL Certificate Monitor | Dynatrace Hub
Example:
Created metric with lot of dimension for splitting the cert information:
You can check you this or other extensions health (eg. errors) with this:
Extensions Health | Dynatrace Hub
I hope it helps.
Best regards,
Mizső
Hi @Maelam
you can query it with such query
fetch `dt.entity.python:certificate_monitor_certificate`
| fieldsAdd lifetime, status = if(lifetime[end] -10d < now(), "🔴", else:if(lifetime[end] -30d< now(), "🟡"))
and this would be the result
Best,
Sini
Hi Sini,
in addition to the lifetime, how do we retrieve other info such as cert name, host name, process name, signer etc.? Thanks.
